ROG RYUJIN 360 ARGB radiator fans always spin at the same speed, even with the pump set to maximum.
Theotorn
Hi everyone, I purchased ROG RYUJIN III 360 ARGB that I installed on my RIG and with which I can control all the cooling speeds (Standard-Turbo and Max) and everything seems to work correctly.
As per the manual I connected the 4 PIN pump connector on the CPU Fan port of my motherboard and the 4 pin connector of the radiator fans on the SYS-FAN 1 port.
However, I noticed that even bringing the heatsink to maximum speed: The pump turns at maximum, the integrated fan of the heatsink turns at maximum...but the radiator fans connected to the SYS-FAN 1 port of the motherboard always remain at the same speed (1481 RPM) when on the technical sheet they indicate that they can reach 2000 RPM. Is all this normal? I was convinced that increasing the performance of the pump would also increase the radiator fans to cool it quickly. Can you help me understand if I connected everything correctly? Is it normal for the radiator fans to always go at the same speed? Many thanks to those who help me. Francesco
dzocece
You can use fanexpert and adjust the fan curves.
Hi and thanks, I don't have an ASUS motherboard but an MSI one...can I still use FANEXPERT? However I can't find this program you mention anywhere...can you help me please?
dzocece
Oh, I see, You can try MSI Dragon Center or Fan Control 😄
