Critical Detection and Firmware Issue – ASUS RYUO IV
Sushiiba
Hello,
I am currently experiencing a major issue with my ASUS RYUO IV.
Initially, everything was working perfectly. However, after replacing my drive with an NVMe SSD and performing a clean Windows installation, the AIO is no longer detected by InfoHub.
System configuration:
  • Motherboard: ASUS X670E (BIOS up to date – latest available version)
  • CPU: AMD Ryzen 9800X3D
  • Operating System: Clean Windows installation
I then attempted to update the firmware using the latest version of InfoHub, but without success.
The update process remains stuck indefinitely:
  • the AIO screen displays a looping GIF,
  • the update does not progress,
  • and the device is not detected by InfoHub.
To rule out a connection issue:
  • I changed the internal USB header used by the AIO screen,
  • I also connected the screen’s USB cable directly to a motherboard USB port,
    with no improvement.
At this point, I am completely stuck.
Additional information:
  • I attempted to install firmware version 1.0.9, but downgrading is not possible.
  • I also tried using InfoHub version 0.74, but the installation always freezes at the end, with no feedback or progress.
  • I have carefully verified multiple times that all drivers are fully up to date, both via Armoury Crate and Windows Update.
I am attaching all requested files for further investigation.
Thank you in advance for your assistance, as this issue is currently completely blocking.
Best regards,
Capture d'écran 2026-02-03 162950.pngCapture d'écran 2026-02-03 163033.pngCapture d'écran 2026-02-03 163048.png
Sushiiba
Fix it by myself, never install windows from front panel case but direct to MB USB, now everything work fine
